Activity Forums Apple Final Cut Pro Legacy Text Placement
  • Posted by Jeremey @ digital innovations on June 29, 2005 at 9:15 pm
    Here is the setup: A guy is standing in a field in front of a tractor. Some titling slides in from the right, behind the guy’s head but in front of the tractor. How is this done? It is appears as if the text floats through or behind his head. I appreciate any help!
    Chris Tompkins replied 21 years, 2 months ago 5 Members · 5 Replies
  • Chris Tompkins
    June 29, 2005 at 11:02 pm
    You have to rotoscope the guy out. Cut out the guy into his own layer.
  • Andrew
    June 30, 2005 at 3:34 am
    What’s the best program to do this in?
  • Bouncing Account needs new email address
    June 30, 2005 at 11:51 am
    [Chris] “rotoscope the guy out”
    Although this will work, on a simply “text behind” effect, its not necessary to do a “full” rotoscope.
    Here’s a quick fix.
    V1: Scene A unaltered (Talent with tractor)
    V2: Title (keyed)
    V3: Scene A again (synced with V1)
    On V3, just put a slightly soft-edged circle wipe closely around the talent’s head.
    If necessary, keyframe the circle to “move” as the talent moves. The titles will be “blanked out” behind the circle that matches the talent’s head motion.
  • Chris Poisson
    June 30, 2005 at 5:37 pm
    Andrew,
    Matte’s idea will work, but to answer your question, IMO the best program to do this inside FCP is Silhouette FX Roto.
  • Chris Tompkins
    June 30, 2005 at 6:36 pm
    You r right. I aways think After Effects and cut out the object – but u r right – that would work. And a lot easier.
    Chris
