Activity Forums Apple Final Cut Pro Legacy Text pixelated
  • Thaxter Clavemarlton
    March 29, 2007 at 1:28 am
    It is essential when attempting to monitor the QUALITY of images in FCP that you use an external NTSC VIDEO Monitor (or PAL, if that’s where you are).
    Especially after you render…
    the Canvas is never high-quality (by design) and should not be used to make determinations of image quality of clips or graphics.
    Video Processing tab.
    “Normal” is default for all Sequences.
    Change this to “Best” and text should clean up.
  • Teddyg
    March 29, 2007 at 3:01 pm
    I did not view it on an external monitor but exported it and viewed it on the computer monitor using Quicktime and found it was still pixelated.
  • Arnie Schlissel
    March 29, 2007 at 6:53 pm
    That’s not the same. You mus see it on a video monitor, at video resolution in video color space.
