Activity Forums Adobe After Effects Text parts slide effect
  • Andrey Sibiryakov
    July 2, 2012 at 11:15 am
    Hello Dragan.
    Here is the script, that can help you.
    https://www.crgreen.com/aescripts/actual_scripts/Separate_Masks_in_Layers.jsx
    I think, you can divide the comp with text or every word on some pieces,
    then, animate one piece, and apply animation to others with a shift.
    And apply other effects above on precomp.
    You know, somewhere around is an Andrew Cramer’s tutorial about positioning layer in depth by a script. I think you can apply it to those 3d rotation word at the end.
  • Dragan Maric
    July 2, 2012 at 3:35 pm
    Thanks Andrey!
    That will work,with this script;
    the only problem is that after applying script i have
    many text layers with chunks of text; and they are not correctly
    in position to form the overall text.
    So i need to manually position each piece of text to get readable text.
    I don t know is somewhere in after effects snap function or something to align text pieces together?
    Thanks for help!
  • Andrey Sibiryakov
    July 2, 2012 at 6:07 pm
    It seems to me, that you can always reset text chunk position if it was precomposed, by pressing ctrl+alt+F.
