Text on colored gradient stripe in Pro Titler
Posted by Joe Gaziv on December 20, 2007 at 10:01 pmHow can text been introduced on top of a colored gradient stripe using V8 Pro Titler?
Edward Troxel replied 18 years, 9 months ago 3 Members · 7 Replies -
Edward Troxel
December 21, 2007 at 2:28 pm -
Joe Gaziv
December 22, 2007 at 8:16 pm[Edward Troxel] “Track 2: Gradient Stripe – sized and positioned correctly”
How do I do that with the Pro Titler?
Edward Troxel
December 23, 2007 at 12:17 am -
Joe Gaziv
December 23, 2007 at 5:59 pmIs it possible to make the color gradient left to right and not top to bottom?
Mike Kujbida
December 23, 2007 at 6:50 pmAssuming you’re talking about one of the color gradient presets in Vegas, all you need to do is to change the “Aspect Ratio Angle” to 0
Joe Gaziv
December 23, 2007 at 10:29 pmIf I understood correctly your suggestion it will cause the stripe to change from being parallel to x axis to being parallel to y axis but the color gradient, in both cases will be in 90 deg to the stripe direction.
What I mean is a narrow stripe which will go on the bottom of the frame (left to right) and its color will change also gradually from left to right. -
Edward Troxel
December 24, 2007 at 2:59 am
