Activity › Forums › Adobe After Effects › Text On A Plaque Effect
  • Text On A Plaque Effect
    Posted by Tim Tippets on March 11, 2024 at 6:31 pm
    Hi everyone!
    I duplicated the text layer and added a stoke via layer styles to the bottom layer to get this effect. I like the way the outside of the stroke looks, but I have stroke gaps between the letters that I’d like to fill in. The goal is to get the top layer to look like text sitting on a solid plaque. I feel like I’m missing something simple here. Image of example attached. Thank you!
    Nils Hammers replied 2 years, 6 months ago 3 Members · 3 Replies
  • Eric Santiago
    March 11, 2024 at 10:53 pm
    Kerning and leading is required.
    For space on return use leading.
    For space between characters use kerning.
    You can also kern individual characters by using Option + Left/Right Arrow.
    Just place the cursor where you wish to apply the kerning.
  • Tim Tippets
    March 12, 2024 at 4:20 am
    When I use kerning to close the gaps it brings the letters so close to each other that they overlap. I’m looking to leave everything where it is and just close the gaps in the white background. Maybe I’m missing something in your reply?
  • Nils Hammers
    March 12, 2024 at 10:10 am
    Is it likely you are looking just for a rectangle which will change its size depending on the text entered, right?
    In that case, you would split your graphics into two layers: one with text, another with rectangular shape. Then there many tutorials around that show how to prime the underlying rectangle so it reacts to the text. Here’s one of those..
