Activity Forums Adobe Illustrator Text object properties? Easy way to change?
  • Text object properties? Easy way to change?
    Posted by Lazlo Hollyfeld on March 6, 2006 at 7:27 pm
    Hi There,
    I’m not sure if this is doable in Photoshop CS2 or not, so I figured I’d ask.
    In illustrator, if you have many text objects, you can use the eyedropper to to copy the properties of one text objects to many. Is something like this interaction available on Photoshop CS2? Is it possible to make styles for text? I saved some tool presets for the text tool, but that just sets up the items in the tool, it doesn’t necessarily apply the preset to the selected text object.
    Any pointers on this would be great!
    Arie
    Lazlo Hollyfeld replied 20 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
