Activity Forums Apple Final Cut Pro Legacy Text moving/ jumping
  • Text moving/ jumping
    Posted by Zombie913 on October 5, 2007 at 5:48 pm
    I am using final cut 5 and when i add text to a section using a fade in transition on the text, the text jumps when the transition is done. It moves. How can i deal with this. it does it using final cut text option and when i use boris it does same thing. What am i doing wrong
    Thomas Imbrigiotta replied 18 years, 10 months ago 3 Members · 2 Replies
  • Tom Meegan
    October 7, 2007 at 11:02 am
    Render the text.
    FCP is dynamically reducing playback quality while the text in on screen so you can see your work in real time. The visual effect sometime looks like a jump when FCP returns to full quality.
    Tom
  • Thomas Imbrigiotta
    October 17, 2007 at 4:01 pm
    Rendering is the key to getting rid of the jump. Try throwing something simple like a garbage matte on the title and then rendering it. Putting your text at an even coordinate sometimes helps as well. If all else fails try removing your dissolves and manually adjusting the opacity with key frames.
