Text Motion messed up after render…
Hi everyone,
First time posting in this forum but I’ve found a couple other answers here before and I’m very grateful to you all.
Today my problem has to do with a simple text motion that is giving me problems. I used a template that fcp offers but wasn’t satisfied with its effect so I decided to modify it. I extended the middle section (so it’d be onscreen longer) by slowing down that part, then I cut and pasted the beginning part (the way the text first appears on screen) and reversed it and put it at the end so it would go off screen the same way. I have to render to see the effect in real time but I scrolled through the final edit of the effect frame-by-frame and it looked exactly how I wanted it…. HOWEVER, after rendering to watch it in real time it was just messed up. The text was moving differently than how it previewed frame-by-frame…
How is that possible? What am I doing wrong? I’ve never had this problem before. Anyway have a clue as to what I could have done, I’d very much appreciate it. Thanks in advance!
Jesse
