Activity Forums VEGAS Pro Text Media: Scripting Question
  • Text Media: Scripting Question
    Posted by Keith Sorbo on April 2, 2005 at 5:10 am
    I think I know the answer to this (NO!) but I want to ask to be sure.
    Is there anyway to access the properties of a generated text media event? I.e., does the API allow access to change things like point size, effects, colors, etc?
    If so, I want to create a script that will allow me to apply uniform properties WITHOUT changing the text content like when using presets.
    Keith
    Edward Troxel replied 21 years, 5 months ago 2 Members · 1 Reply
  • Edward Troxel
    April 2, 2005 at 12:20 pm
    It does not allow adjusting the individual settings. However, it DOES allow picking presets. So if you had a preset for every combination you need you could simply pick the proper preset to add a keyframe. However, you’d have a LOT of setup work to get every combination you need.
    So… as you suspected the answer is NO.
    Edward Troxel
    JETDV Scripts
