Activity Forums VEGAS Pro Text Media Generator
  • Text Media Generator
    Posted by Mashy P on July 11, 2007 at 4:29 pm
    i am trying to add text to a vegus project but the edit tabs dont seem to be there, how do you activate them,its driving me mad,Pete
    David Whelan replied 15 years, 4 months ago 6 Members · 7 Replies
  • 7 Replies
  • Simon Laidlaw
    July 13, 2007 at 6:58 am
    Just want to be clear. You are clicking on Insert… text media? Does it appear in the middle of the screen? If you just drag it into your tabbed media box it will open up there next time you use it.
  • Lauraitt
    July 13, 2007 at 9:05 am
    Theres 3 small buttons on the event its the top one that you use to edit the text. Its a green button. Is this what you were looking for ?
  • Clarkt
    August 28, 2007 at 4:26 am
    I’m having the same problem. If I click the green button icon in a text event – nothing happens. If I right click it and select ‘Edit..” nothing happens. Where is the text editor window???? Heck I can’t even get the text window to open when I first drag and drop a text event to the timeline. It used to work but now I don’t get any editing window at all. It has totally disappeared! help! Vegas Movie Studio 8.0
  • Lauraitt
    August 28, 2007 at 7:32 am
    Dont know if this will work, but make sure there not locked. Go to edit –> switches —> uncheck lock.
    Good luck fixing it
  • David Whelan
    May 7, 2011 at 10:27 pm
    I’m having the same problem have you had any luck fixing it????
    Any help would be much appreciated 😀
  • Edward Troxel
    May 8, 2011 at 12:09 pm
    David, odds are the dialog box has been moved “off the screen” typically it is found hidden under the “Start” bar. Set the start bar to auto-hide, locate that dialog, and then drag it back to the screen. Worst case, change the screen to a higher resolution, move that window back to the middle of the screen, and then reset the screen back to its original resolution.
    Edward Troxel
    JETDV Scripts
  • David Whelan
    May 8, 2011 at 12:16 pm
    It was simple I have fixed it. Somehow I had managed to remove the box from site. It wasn’t hidden like you said. It was simply gone. So I just did a system restore. Quite simple.
