Activity Forums Adobe After Effects Text Mask from Illustrator?
  • Text Mask from Illustrator?
    Posted by Shannon Appleby on September 18, 2008 at 1:49 pm
    I have text created in Illustrator.
    I need a mask that outlines the text while in after effects so that I can apply some effects to animate the stroke / outer edges of the text.
    I do not want to hand make a mask for each letter.
    Is there a way to generate a mask in AE based on the vector text?
    If not, is there a way to generate that mask in Illustrator that will come over with the file into AE?
    Example, you have Text. You want the Scribble effect to apply to a mask of that layer that outlines the text and I don’t mean just a box around it.
    Please help if you have any ideas.
    Shannon Appleby
    My Boyz Productions
    J&P Cycles Inc.
    Anamosa, Iowa
    AVID Xpress Pro, Adobe Premiere, After Effects, Photoshop, PC, NO MAC, Brightcove
    Rachael Jones replied 13 years, 7 months ago 4 Members · 4 Replies
  • Mark
    September 18, 2008 at 2:10 pm
    Layer-convert to outlines
    Layer-Auto trace.
    Mark
    Mark Harvey
    Senior Editor
    Le R
  • Kevin Camp
    September 18, 2008 at 3:16 pm
    if you didn’t under stand marks somewhat cryptic response, i’ll elaborate.
    if you have the ai file in after effects as a layer (text that is keyed), you could select that layer, then choose layer>auto trace to trace the outer edges of the text and create vector paths of the text that can be used with effects that use vectors.
    that’s probably the easiest way with what i think you have right now, though it may not be the most precise.
    if you need more accurate paths, you can create the paths in ai. select the text the choose text>create outlines. now you can copy and past those paths on a solid in ae as a mask. this will give you precise paths to work with.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Mark
    September 18, 2008 at 3:22 pm
    Oops, sorry about the short post…thanks for clarifying Kevin.
    Mark
    Mark Harvey
    Senior Editor
    Le R
  • Rachael Jones
    February 12, 2013 at 11:17 am
