Activity Forums Adobe After Effects Expressions Text: make “start” value change over “text length” frames
  • Text: make “start” value change over “text length” frames
    Posted by Alekos Mazzolotti on June 10, 2020 at 10:00 pm
    I use a lot the “typewriter” effect in AE and, as a personal standard, when setting the distance between the 2 keyframes that make the “start” property go from 0% to 100%, I simply count the characters in the word and apply this quantity manually, in frames, so that the letters appear 1/frame.
    I was wondering… Is there a way to use an expression to make this property go from 0% to 100% across a number os frames equal to the text length?
    Alekos Mazzolotti replied 6 years, 3 months ago 3 Members · 4 Replies
  • Dan Ebberts
    June 11, 2020 at 12:28 am
    Assuming you leave Units set to Percentage, something like this should work:
    n = text.sourceText.value.length;
    t = time – inPoint;
    (t/framesToTime(n))*100
    Dan
  • Alekos Mazzolotti
    June 11, 2020 at 2:12 pm
    Beautiful! Works as clock!!
    Just out of curiosity, what if I were to apply the same concept to the “offset” property, in ramp up mode, that, instead of going from 0 to 100, must be set to variate from -100 to +100?
    Thanks a huge lot for your help!
  • Ranveer Singh
    June 12, 2020 at 8:29 am
    Add this expression to the offset property.
    Remove the keyframes from start. Set it to 0
    I used this expression in After Effects 2020.
    txt=text.sourceText;
    t=inPoint;
    linear(time,t,t+framesToTime(txt.length),-100,100);
  • Alekos Mazzolotti
    June 12, 2020 at 3:34 pm
    Wonderful!
    One last question: how do I like your answer a thousand times? ahahahah
    Thanks a huge lot, friend.
