Activity Forums Adobe After Effects Text looks jagged in 32 bit
  • Text looks jagged in 32 bit
    Posted by Jerry Sneede on April 27, 2011 at 2:50 pm
    I want to take advantage of the nice blurs you can get with super white text in 32 bit, but the text looks a bit jagged in 32 bit. Is this a font thing or something?
    Darby Edelen replied 15 years, 4 months ago 3 Members · 9 Replies
  • 9 Replies
  • Jerry Sneede
    April 27, 2011 at 3:08 pm
    The text looks jagged before any effects are applied. I open a new composition, use the text tool, and it’s jagged right from the start.
  • Jerry Sneede
    April 27, 2011 at 3:43 pm
    I wish that was the case. The comp is square pixels. I’ve rendered a test and the text looks jagged viewing in the finder and Final Cut.
  • Jerry Sneede
    April 27, 2011 at 4:07 pm
    Nope, doesn’t look good in the crt monitor either.
    I can click through the 8, 16 and 32 bit settings and can see the text go from being nice and smooth on 8 and 16, then go jagged on 32.
    Maybe I shouldn’t have posted this question in the Basic forum. I’ve been using AE for quite a while, just thought this might be a simple thing. I might try posting in the other forum, see if anyone else has had this problem.
  • Michael Szalapski
    April 27, 2011 at 4:12 pm
    What font are you using? Does it look fine in 16 bit and 8 bit? Can you provide screenshots?
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Jerry Sneede
    April 27, 2011 at 4:50 pm
    I don’t think you can have a comp that’s 16 and one that’s 32 – it’s the project itself that is one or the other.
    On your AE, do you get the same results I am? It doesn’t matter what comp size or resolution I choose – I open a comp, put down some text, make it super white (like 3,3,3 on the RGB) and it’s jagged.
  • Jerry Sneede
    April 27, 2011 at 5:21 pm
    It doesn’t seem to matter what font I use. Yes, they look fine in 8 and 16. Not sure how to include screen shot.
  • Jerry Sneede
    April 27, 2011 at 7:40 pm
    Yes, when I do two regular white, top one set to add, it gets jagged just like when it’s set to super white (this is in 32 bit)
  • Michael Szalapski
    April 28, 2011 at 2:05 pm
    Are you using OpenGL?
    – The Great Szalam
  • Darby Edelen
    May 3, 2011 at 4:52 pm
    [Jerry Sneede] “On your AE, do you get the same results I am? It doesn’t matter what comp size or resolution I choose – I open a comp, put down some text, make it super white (like 3,3,3 on the RGB) and it’s jagged.”
    Simple answer is don’t go above white if you’re not blurring your text.
    In the same way that values above white will give you more intense blurs, they intensify the anti-aliasing sampling that is done on the edges of the text which causes the anti-aliasing to be less effective.
    An alternative if you must have super white text immediately would be apply a very slight blur to it, but I would consider animating the text color from white to super white using a text animator.
    Darby Edelen
