Activity Forums Apple Final Cut Pro Legacy Text looks funny
  • Text looks funny
    Posted by Bexineffex on June 9, 2006 at 4:45 pm
    Not funny ha ha, but funny weird. What’s up with that? It looks okay in the viewer when I’m creating titlecards with the text generator, but once it’s rendered it looks pixelated and nasty. Any suggestions?
    Debe replied 20 years, 2 months ago 3 Members · 4 Replies
  • Debe
    June 9, 2006 at 5:14 pm
    Tell us about your monitoring set up, and your computer specs and which versions of FCP, QT, & the OS you are using.
    debe
  • Josh Weiss
    June 9, 2006 at 6:08 pm
    Check your sequence settings and change the Field dominance to none. That will probably solve your issue.
  • Bexineffex
    June 11, 2006 at 2:02 pm
    i set the field dominance to none, but unfortunately that didn’t solve the problem. any other ideas? i’m using a powerbook G4, with OS 10.3.9, Final Cut HD 4.5, Quicktime 7.1.1.
  • Debe
    June 11, 2006 at 3:30 pm
    We still need to know if you are using an external video monitor or if you are trying to judge this quality on the computer screen.
    If you are trying to judge it on the computer screen, that’s the problem, and you probably do not have an issue with your text. The canvas, by design, only shows about 1/4 resolution. True quality can only be assessed on an external video monitor, or by exporting a QT movie and looking at it in High Quality playback. External monitor is less time consuming.
    In a pinch, even a TV will work. Check out the manual for proper external audio and video monitors.
    If you are monitoring externally, it might be that you are mixing QT 7 with Panther. Panther and QT 7 don’t play well together. Your options there may be to upgrade your OS and FCP, or to revert back to QT 6.5.
    debe
