Activity Forums Adobe After Effects text lines appear behind each other in text area
  • text lines appear behind each other in text area
    Posted by Dolphbean on October 26, 2007 at 10:08 am
    I have a really annoying problem that is probably really easy to solve but i can’t figure it out. (forgive my noobie status)
    When i draw a text area and write my text the first line appears fine then the text i write after just appears directly behind the fist line. I want it to continue on to a line below.
    is it a problem with my settings?
    Many thanks in advance.
    Kevin Camp replied 18 years, 10 months ago 2 Members · 1 Reply
  • Kevin Camp
    October 26, 2007 at 2:55 pm
    it sounds like the leading (or line spacing) is set to low.
    look at the character palette and make sure the leading is set to auto (or a value about the same as the point size). the leading is the value just to the right of the size.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
