Activity Forums Adobe After Effects Text leading not working correctly
  • Text leading not working correctly
    Posted by Martin Schlesinger on December 7, 2011 at 5:00 pm
    I’ve had this issue for a while now, and not sure what caused it. The text leading in After Effects doesn’t seem to be working properly. Hitting the enter key after typing a line of text results in a huge gap between the lines, even with 0 leading. I just tried the shift+control+alt trick to reset preferences, but no dice. Any suggestions? I’ve attached a pic to show what I’m experiencing.
    Thanks in advance.
    Sincerely,
    Marty
    Martin Schlesinger replied 14 years, 8 months ago 2 Members · 2 Replies
  • John Cuevas
    December 7, 2011 at 5:27 pm
    Switch to the paragraph tab and change the second column to 0. That is the “Add space before paragraph” adjustment.
    Johnny Cuevas, Editor
    Thinkck.com
  • Martin Schlesinger
    December 7, 2011 at 10:33 pm
    Doh! Well, now I know! Thanks for the fix John.
