Activity › Forums › Adobe After Effects › Text Layers
  • Itamar Kool
    April 8, 2005 at 12:18 pm
    Create these symbols in a ‘Word’ like program. Then copy and past them into your After Effects text layer
    Kool En De Anderen
    dual 1.8 gig G5/Mac OS 10.3.7/Kona SD/FCP 4.5/AE 6.5 Pro
    http://www.koolendeanderen.nl
  • Steve Roberts
    April 8, 2005 at 12:29 pm
    I’m not sure why you’re having that problem.
    I select the text tool, click in the comp windows, then hold down the alt key, then type the four-digit code for the character on the numeric keypad, then release the alt key.
    If you’re having trouble with the Euro character, you might need to download this font:
    https://www.fonts.com/FindFonts/Euro.htm
    Hope that helps,
    Steve
  • Simon Roughan
    April 8, 2005 at 1:06 pm
    Where do you find these number codes?
    simon
  • Steve Roberts
    April 8, 2005 at 1:25 pm
    I got mine from Sean Cavanaugh’s Digital Type Design Guide, but you can google “alt codes”.
    Try https://home.olemiss.edu/~ccjjs/OCUG/Oct-98-nl.html .
    Steve
  • Simon Roughan
    April 8, 2005 at 3:15 pm
    Thanks mate 🙂
