Activity Forums Adobe After Effects Text Layer>Mask>New Layer creates mask that pasted in solid layer, is always above and right of the text position. Why?
  • Text Layer>Mask>New Layer creates mask that pasted in solid layer, is always above and right of the text position. Why?
    Posted by Russ Adams on December 18, 2016 at 1:18 am
    In CS6 when I select a text layer and apply Layer>Mask>New Mask and then change the mask to Rectangle, it masks perfectly. But when I paste this mask group into a solid (to cut a white background), the mask appears above and to the right of the position in the original text layer. I can of course drag this back to the right place.
    But this seems to be trying to tell me something about the relationship between a mask created by AE from a text layer and the solid layer it gets pasted into. I’ve gone back through Meyers chapters on Text and Masks carefully. But I don’t get the method behind this madness.
    Any thoughts would be appreciated!
    Russ Adams replied 9 years, 7 months ago 2 Members · 4 Replies
  • Greg Gesch
    December 18, 2016 at 2:11 am
    Hi, it seems that when you copy the mask it jumps to the center point of the solid. This may have something to do with the size/position of the two layers not being the same.
  • Russ Adams
    December 18, 2016 at 8:49 pm
    Thanks! I see that when I put the text position point on 960,540 the text lines up with the white solid masked behind it. Looks like one should create captions and citations on normal 1920 x 1080 text layers. Then layer, mask, new mask for appropriate cutouts (made rectangular), before being copied to white solid.
    Nest the white-backed text and only then change text position to where it needs to be.
    Thanks to your suggestion we’re back on the right track! Happy holidays!
  • Greg Gesch
    December 19, 2016 at 12:19 am
    HI, or you can pickwhip the solid’s position to the text’s position. Then they are locked together in the original text position.
  • Russ Adams
    January 24, 2017 at 10:36 pm
    Thanks, your help sent me in the right direction.
    Thanks again!
