Activity › Forums › Adobe After Effects Expressions › Text Layer Scale Based on Amount of Characters
Posted by Thomas Hardy on July 27, 2011 at 12:12 amLet’s say I have a text layer with 25 characters and another text layer with 10 characters.
I want both using the same amount of space in the composition automatically so I don’t need to adjust every time the text (I have to render a lot of times the same composition with different texts), the only thing I can think about is scale the text layers based on the amount of characters, any idea how to do this with expressions or scripts?
Thomas Hardy.-
Newbie and Learning.Thomas Hardy replied 15 years, 2 months ago 2 Members · 11 Replies -
Dan Ebberts
July 27, 2011 at 12:31 amYou could try something like this for the layer’s scale:
[12/text.sourceText.length*100,value[1]]
Change the 12 to the number of characters you want for a line scaled to 100%. It won’t be real accurate unless you use a mono-spaced font, but it might be close enough.
Dan
Thomas Hardy
July 27, 2011 at 1:11 amThank you so much, but it scales only the width, not the height.
Any ideas how to fix that?
Thomas Hardy.-
Newbie and Learning. -
Thomas Hardy
July 27, 2011 at 2:06 amAmazing! Thanks!
Where are you reading about expressions !? I can’t find any good guide or doc.
Thomas Hardy.-
Thomas Hardy
July 27, 2011 at 8:31 amOk, now I understand a bit how it works, but I’m trying to so something that I don’t know if possible and I can’t find any list of “commands” or something.
Can I assign different values to scale depending on the amount of characters?
I mean, something like
if text.characters = 10 then
[100,100]if text.characters = 11 then
[90,90]if text.characters = 12 then
[80,80]if text.characters = 13 then
[70,70]if text.characters = 14 then
[60,60]if text.characters = 15 then
[50,50]Is this possible with expressions?
Thomas Hardy.-
Thomas Hardy
July 27, 2011 at 9:51 pmNop, that’s the same but using only a 10% scale with 20 chars.
What I need is specify a scale for each character value.
If 20 characters written then 100% scale
If 18 characters written then 95% scale
If 16 characters wtitten then 90% scaleetc…
Thomas Hardy.-
Dan Ebberts
July 27, 2011 at 10:40 pmWell, I’m confused because last time you said 10 characters at 100%, but this gives the 20 at 100% progression:
s = 50 + text.sourceText.length*2.5;
[s,s]If that’s not it, I’m really clueless.
Dan
Thomas Hardy
July 28, 2011 at 6:09 amI will explain, let’s say I have a red rectangle
https://imageshack.us/photo/my-images/695/screen1xx.jpg/
This rectangle is the allowed margin for the text, any partial text out of this rectangle looks bad.
Now, this looks ok:
https://imageshack.us/photo/my-images/20/screen2nc.jpg/
If I use this expression:
s = 12/text.sourceText.length*100;
[s,s]When I have less than 5 characters the size is HUGE and out of margin, it must be centered in the rectangle even if only 1, 2, 3 or 5 characters too.
https://www.youtube.com/watch?v=GDIBK2uYcx4
I want it to look like this:
https://imageshack.us/photo/my-images/811/screen4q.jpg/
Thomas Hardy.-
Dan Ebberts
July 28, 2011 at 1:46 pmSomething like this, maybe:
s = 12/Math.max(text.sourceText.length,6)*100;
[s,s]Dan
