Activity Forums Adobe After Effects Text layer progressive alpha
  • Text layer progressive alpha
    Posted by Deathwolf on May 5, 2005 at 12:42 am
    Hi all,
    Anyones knows if it’s possible to use the range animator to do a continuous alpha fade in/fade out instead of per letter.
    Per letter works relatively well but in the case of big letters it doesnt look that good.
    Up to now i did it either using a gradient layer that i moved, or a mask with feather, but when there’s a lot of text these 2 solutions can get very unhandy to do.
    Thanks for any help,
    Paul-Kenji Cahier
    Filip Vandueren replied 21 years, 4 months ago 3 Members · 3 Replies
  • John Dickinson
    May 5, 2005 at 1:05 am
    In the Range Selector’s Advanced menu try using the RAMP UP setting. You’ll then need to animate the OFFSET rather than START or END.
    John Dickinson
    Motionworks
    https://www.motionworks.com.au
  • Deathwolf
    May 5, 2005 at 3:12 am
    that still works with a per char alpha change:/
  • Filip Vandueren
    May 6, 2005 at 1:04 am
    That’s just the way the textacy animation works. On a per-character basis.
    I’d use the method you described (gradient layer as a trackmatte) or if you want to do it on 1 layer,
    use “Alpha Ramp” Plugin (red giant software Image Lounge), it’s on the CD of Creating Motion Graphics by the Meyers
