Activity › Forums › Apple Motion › Text Layer Mask affected by Color Correction …
  • Text Layer Mask affected by Color Correction …
    Posted by Paul Figgiani on November 21, 2012 at 7:29 pm
    Thanks for the help.
    I have a text prompt that pops up in a published effect applied to a FCPX clip controlled by a checkbox widget. My problem is when I apply color correction to the clip – the text prompt is affected by the correction. For example if I test this with a heavy dose of green – the text turns green. It should remain solid gray.
    The text layer resides in a Group by itself. I cloned the layer and added mask to it. I used the text layer as the Mask Source. Maybe I screwed something up in the Mask options? Regardless – I can’t figure out how to keep the text on top of the video and have it unaffected by color correction/saturation/exposure adjustments.
    Thanks again.
    -paul.
    Paul Figgiani replied 13 years, 10 months ago 2 Members · 4 Replies
  • Mark Spencer
    November 21, 2012 at 7:47 pm
    Paul, make the text a Title effect rather than an -um- effect effect. That way it will be above the clip you are color correcting and therefore independent of the correction.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Paul Figgiani
    November 21, 2012 at 7:56 pm
    Mark,
    Thanks – but that’s not what I’m trying to do. The display of the text – based on the check box setting is wrapped into an Effect. Are you saying that I can’t have the text prompt be independent of the video as it would be in a Title?
    Thanks again.
    -paul.
  • Mark Spencer
    November 21, 2012 at 7:59 pm
    I’m saying the color corrections are applied after effects, so they will impact any applied effects.
    Mark Spencer
  • Paul Figgiani
    November 21, 2012 at 8:21 pm
    Got it. Thanks again, Mark.
    -paul.
