Text layer flickering on render. Vegas 13
Posted by Luke Gibson on September 25, 2018 at 3:41 amVideo capture of the issue: https://www.useloom.com/share/c0857a0989024457838d90a8f8496031
In the video it shows playback in Vegas is fine, but once the file is rendered the text flicks on and off, each time the file is rendered it seems to change too, several times the text and url flicker multiple times and alternate, seems totally random. Never had any issue like this before. Any ideas?
Cheers
Steve Rhoden replied 7 years, 11 months ago 3 Members · 12 Replies -
Graham Bernard
September 25, 2018 at 8:11 am[Luke Gibson] “Any ideas?”
Yes, lots. But I’d need to see more Timeline detail, your render details, your project settings etc. Why a render doesn’t perform in the way the Preview appears can be as simple as the requirement for a higher bitrate. But let’s see just exactly what it is that VP14 is having to wrangle.
And BTW, previous projects may have worked could be the result of many, many reasons ???? .
* Grazie
Cameras: Canon XF300 + PowerShot SX50HS Bridge -
Luke Gibson
September 25, 2018 at 5:36 pmProject settings:
1920×1080
field order: progressive
FR 29.970
pixel aspect 1.0
8-bit
Best
Gaussian
NoneRender settings: MainConcept AVC/AAC .mp4
Main
FR: 29.970
Allow source to adjust frame rate
pixel aspect 1.0
Ref frames 4
VBR: 5Mbs – 10Mbs and CBR: 10Mbs
Slices 4
Render using CUDA
Enable progressive download. -
Graham Bernard
September 25, 2018 at 6:13 pmThanks for that Luke. Do try selecting a Region of the area that’s producing these anomalies and to start with Render to something uncompressed. Report back. I’m thinking that there is a lot of maths going on trying to go to MP4.
Interesting.
* Grazie
Luke Gibson
September 25, 2018 at 7:00 pmUncompressed AVI doesn’t seem to be affected.
I also tried adjusting most of the rendering setting one at a time and the problem still occurs on mp4
higher bitrate
number of slices 1, 4, 32
reference frames 4, 1, 10
profile: Main, High and Baseline
disabling progressive download
Enabling allow source to adjust frame rate -
Graham Bernard
September 25, 2018 at 7:03 pm[Luke Gibson] “Uncompressed AVI doesn’t seem to be affected.”
Luke? Are you saying that Uncompressed cures the issue?
* Grazie
Luke Gibson
September 26, 2018 at 9:37 amHi Graham,
It’s a work around, not a cure, and not a very helpful one it takes almost 10 times longer to render and over 100 times the file size.
Cheers
Graham Bernard
September 26, 2018 at 9:53 am[Luke Gibson] “It’s a work around, not a cure, and not a very helpful one it takes almost 10 times longer to render and over 100 times the file size. “
It was not meant as a work around nor as a cure. It was and is meant as an indication that your Timeline editing does work. We call this evidence-based results. And, as I don’t have your Veg, you can now confirm it is purely your choice of Render combined with your Timeline.
Somewhere within your PC and that MP4 is why the Render process is coming up pants.
* Grazie
Steve Rhoden
September 26, 2018 at 10:00 amLuke right click on your problematic event, and go to switches then select Reduce Interlace Flicker.
See if that renders a difference.Steve Rhoden (Cow Leader)
Film Maker & VFX Artist.
Owner of Filmex Creative Media.
Samples of my Work and Company can be seen here:
https://www.facebook.com/FilmexCreativeMedia -
Luke Gibson
September 27, 2018 at 11:33 amHi Graham,
You asked me if it “cured” the issue. Hence my reply. Sorry if I misunderstood.
Luke Gibson
September 27, 2018 at 11:35 amHi Steve,
Thanks I’ll try that and let you know if it makes a difference. For the moment I switched to rendering the text as a PNG layer in photoshop, which seems to work fine. Only text layers appear to be affected if that helps.
