Activity › Forums › Apple Final Cut Pro Legacy › Text Layer Drops Brightness
Posted by Ravi Kanda on August 27, 2010 at 8:14 pmHi guys
When I add text to my video, the point when it comes in and goes out, I experience a drop in brightness. Once the text disappears, everything is back to normal again.
Any ideas what I’m doing wrong? Or what I need to do to rectify this?
I’ve added no fades to the text.
I’ve uploaded my problem onto youtube:
https://www.youtube.com/watch?v=520BlKEiHZk&feature=player_embedded
If you cannot see the video well, download the mov file here:
https://www.sendspace.com/file/8ldrya
Thanks.
Elisa Rice replied 15 years, 1 month ago 5 Members · 8 Replies -
John Fishback
August 27, 2010 at 8:41 pmMore information is needed. What codec are you editing with? What are your sequence settings? What text generator are you using? Do you have a render line showing?
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)Pro Tools HD w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Ravi Kanda
August 27, 2010 at 8:47 pmHey John
Thanks for replying.
I’ve uploaded another video. Hopefully this video answers your questions:
https://www.youtube.com/watch?v=cuLM2PYHlio
I hope you can help resolve this.
I’m a FCP newbie so I might have the settings incorrect.
Gary Adcock
August 27, 2010 at 8:53 pmI am not interested in giving you hits on you tube- what is the problem with writing the specs.
On a 3G connection that is unreadable – and since you did not bother to speak during- it is impossible to tell what you have done.
TURN OFF the RT extreme engine and render the file out – does it still happen?
if so it is something your workflow.gary adcock
Studio37Post and Production Workflow Consultant
Production and Post Stereographer
Chicago, ILhttps://blogs.creativecow.net/24640
Ravi Kanda
August 28, 2010 at 1:31 pmI’d like to add that this is an animation video I’m trying to add text to. So the compressor setting is set to ‘Animation’
Could this be the reason for the jump in levels?
If so, what should I change?
Elisa Rice
July 22, 2011 at 2:56 amDid you find out how to resolve this issue? I’m having the same problem in reverse (footage getting brighter during text not darker) and I’ve tried all the text generators in FCP and still can’t get it to change. I’m using ProRes 422 (HQ) for all my footage and sequence.
I’m new to editing so I don’t know what other info would be helpful about my configuration, but any info on how to resolve this would be so wonderful (I’m way over my deadline as it is).
– Elisa -
Sion Parkinson
August 25, 2011 at 5:07 pmElisa –
Did you manage to resolve this? I’m experiencing the same thing! Text layer increases brightness then drops again.
Thanks.
Elisa Rice
August 27, 2011 at 3:02 amHey Sion,
Yes, I did resolve this issue….. sort of. Here’s the deal – apparently it has to do with how Final Cut renders the video in RGB. Apparently, if you go into your sequence settings (see attached screenshot), you can tell FCP to render in a higher quality which isn’t always possible given what machine you’re using (I ran into issues because I’m on a laptop).
Anyways, if you switch from RGB to YUV, you shouldn’t see the brightness shift anymore.
Unfortunately….. the problem arose for me again when I went to publish my video using compressor. As my friend explains it to me, there’s no option to choose YUV over RGB in compressor, and FCP tells Compressor exactly where the troublesome areas (like text) are so that the brightness shifts still remained when I tried to compress my video.
So, the only work-around I could come up with was just to export my uncompressed file and upload it straight to youtube as is. Sure, it took over 14 hours, but I didn’t know what else to do at that point.
Hope this helps, and let me know if you’re able to solve the secondary compressor issue since I’d definitely like to know.
