Activity Forums Adobe After Effects Text inside of text
  • Text inside of text
    Posted by James Quetant on August 27, 2014 at 2:07 am
    Hey what’s going on guys… So I’m working on a kinetic typography project & I’m trying to place text inside of bigger text.
    The way I got it set up, the text that I want placed inside of the bigger text is zoomed in with the camera, I wanted the Bigger text to opaque in & fill the screen, then to zoom out & reveal the bigger text… Hope the way I explained it didn’t throw anyone off
    John Cuevas replied 12 years ago 2 Members · 1 Reply
  • John Cuevas
    August 28, 2014 at 11:59 am
    You just need to parent one of the text’s to the other(adjust anchor points first). Maybe add a quick dissolve on your smaller text. Another method would be to use an ease expression to control the scale from one layer to the other(I like that one better) Here’s an example proeject with both methods.
    7920_textzoom.aep.zip
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
