Activity › Forums › Apple Final Cut Pro Legacy › text in final cut
text in final cut
Posted by Alan Scheinsohn on March 19, 2007 at 6:52 ami’m working in uncompress 10bit, when i render a text effect it seems to loose a lot of quality. Why? (my render resolution is at %100)
Steve Braker replied 19 years, 6 months ago 8 Members · 9 Replies -
Jerry Hofmann
March 19, 2007 at 1:46 pmAre you judging the quality on an external video monitor? If not, try that… the Canvas only shows a proxy of the actual resolution you are working with.
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
Peter Dewit
March 19, 2007 at 2:22 pmalso I’d make sure in your render settings everything is checked including “full”
Curious Turtle
March 19, 2007 at 3:30 pmAnd finally, if you’re doing any scaling/repositioning of the text, use the Boris Title 3D text tool.
Curious Turtle Professional Video
Training | Editing |Support -
Arnie Schlissel
March 19, 2007 at 6:15 pmAnd a littel more finally- only scale or position text using the Controls tab, not the Motion tab.
Evan Schafer
March 19, 2007 at 6:22 pmAnd a little more finally than that – make sure your text X,Y position is at an EVEN and WHOLE integer. If its at 293.65, 95.3…round up to 294, 96. Make sense?
Chris Babbitt
March 19, 2007 at 9:42 pmThis is not an issue in Title 3D, only in the FCP text generator.
Evan Schafer
March 19, 2007 at 11:23 pmNot so for me. All I use for static titles is the Title 3D tool, and I can assure you, its an issue! Maybe it got cleared up in the 5.1.4 update and I never heard about it, but Im at 5.1.2 and its there. In fact, its been an issue, for me at least, since FCP 4. And its not a huge deal, I just make X,Y even and whole and move on. Just part of the routine…
Alan Scheinsohn
March 20, 2007 at 4:05 amthe problem is with lcd monitors, when i render the text effect it looses a lot of quality, but watchin it in a tube monitor it looks fine
(sorry for my bad english) -
Steve Braker
March 20, 2007 at 5:21 pmThen that’s a monitoring issue, not a problem with the text.
Your external CRT shows The Truth about any interlaced video signal. Anything you see on an LCD – within FCP or not – has been compromised in one or more ways to show it to you.
If your distribution will be on LCDs (i.e. web video), then you need to work on best conversion techniques for that output only. If it will be via both traditional TV and web video, then you will have different outputs for each.
