Activity › Forums › Adobe After Effects › Text in a swirl????
Text in a swirl????
Posted by Jason on March 11, 2006 at 4:31 amHello all,
I am trying to get a full line of text to start off screen and move in from the right and start making a circle and the first letter on back keeps getting smaller and smaller (like a tornado, but looking at it from the top)
Am I saying this right????
Kinda like this, but I want it to move —-> https://www.heathrowe.com/tuts/spiraltext.asp
Thank you
JAsonYossarian replied 20 years, 6 months ago 5 Members · 6 Replies -
Serge Hamad
March 11, 2006 at 5:02 amHi,
Here is a classic method:
-Draw a path on a solid in AE using the pen tool or better if you have Illustrator use the spiral tool then copy/paste your path to a solid in AE.
-Apply Path Text to your solid
-Select your path as a custom path in the path options menu.
-Animate the size of your text as well as the left margin.Salut.
Serge -
Sam Moulton
March 11, 2006 at 6:19 amyou can also use the text tool in 6.5 and 7 and just draw a mask path directly on the text layer. Then in the time line you’ll find path options. pick the mask and then for fun try one of the text animate in pre-sets. I just did this using spin in by letter and it was amazing.
Jason
March 11, 2006 at 4:21 pmI must not be doing something right????
I am using AE 6 and Illustrator CS
I have the swirl in illustrator and when I import it into AE I get lost on what to do next????
In the custom path drop down box it has no options????
Thank you
Jason -
Jason
March 11, 2006 at 5:22 pmOk I got the first part finally 🙂
Now can I get the text to scale from the front to the back over time?
Ex. The first letter gets smaller before the last as it moves down the swirl?
Thank you
JAson -
Zander
March 13, 2006 at 6:29 amid say key frame but im sure there’s a better way, like a displacement map, i dunno
im guessing something with keyframing, this is interesting, ive been meaning to try this my self
Yossarian
March 13, 2006 at 2:15 pmI think you might be best off using the Text animation menu within the text layer. Twirl down the text layer’s transform properties, click on the arrow next to “Text” (on the right side), and choose scale to animate. You’ll pretty much have to play with it from there – you’re going to want to change the scale property (not keyframe it, just change it once) and keyframe the “end” property (under “range selector”) to match the timing you want (you can also select the path text option in here instead of adding the path text effect before doing this).
For what you’re doing, you might also play with the “shape” option (under “advanced”) – ramp down might work for you.
Hope this helps some; sorry if I just told you things you already know.
