Activity › Forums › Adobe After Effects Expressions › text in 3d space
text in 3d space
Posted by Jase on September 16, 2006 at 4:01 amHi
trying to do a ticker tape scroll round a cylinder shape. I’ve tried the 3d ribbon tutorial – but is a bit over my head and have searched through the forum…
Can’t use cylinder effect because it’s not true 2.5D. Path text then alter orientation? must be an easy way to to this…
Jason.Mike Clasby replied 20 years ago 3 Members · 3 Replies -
Mylenium
September 16, 2006 at 7:41 am[jase] “must be an easy way to to this…”
A 3D program? Invigorator? *giggle* Sorry, you’re looking for an easy solution where there is none. There is simply no built-in method or effect in AE that could achieve it. So sink yolur teeth again into that ribbon text tute and try to figure it out. If you have the dollars, get Invigorator.
Mylenium
[Pour Myl
Jase
September 17, 2006 at 11:48 pmhehe
*mental note* add to after effects want list after intel version, final cut pro aaf import, nucleo pro for free then.
buy propeller hat, learn expressions and code, dream of clients that don’t make changes.*sigh*
Mike Clasby
September 18, 2006 at 9:25 amWell, there is one way I found to get text to scroll around AE’s 2.5 D. This is not CC Cylinder or CC Sphere. Take a look at this great AE Enhancer’s Discussion project by oscarus,
https://www.aenhancers.com/viewtopic.php?t=160&highlight=sphere
The aep has 44 solids making a sphere, each solid is 768×576, so I changed them to a size I thought would be more for my text size, 100×100. I changed one, deleted the other large solids, then dupped the 100×100 to fill the sphere again. To the solid layers I applied Effect>Text>Basic Text, I didn’t use the Text Tool because basic text drops the Text right in the middle of the solid, I used one letter per solid, changed the Size to 100. Rotations are done in the Nul 1 layer (Rayon is radius methinks (French??)). Here’s a mov of the result.
https://media.putfile.com/sphereoscarusText
And a download here:
https://www.nitroshare.com/v/3134564/1158570183855.mov.html
The text rotates around another instance of the Comp “Sphere”, this one with the Solids changed to 150×150, this and the text comp (above) put in a new comp and moved around in AE 3D until the text rotates around the sphere. It works.
