Activity › Forums › VEGAS Pro › Text Graphic copyright insertion
  • Text Graphic copyright insertion
    Posted by William Mims on August 15, 2011 at 5:19 pm
    On any Microsoft Word program I can go into “symbols” to use the copyright symbol in my word file. How do I get that symbol so I can have a title graphic that says: C 2011 etc.
    Mims
    Mike Kujbida replied 15 years, 1 month ago 4 Members · 6 Replies
  • Mike Hinkel
    August 15, 2011 at 6:32 pm
    Alt 0169 will give you the © symbol. copyright
    Alt 0174 will give you the ® symbol. registered trademark
  • William Mims
    August 15, 2011 at 7:07 pm
    Mike: Thank you for getting right back on this, however that did not work, instead a spreadsheet comes up that is labeled “Edit Details”. Now just to be clear, I placed the typing cursor right before the year and held the ALT key down while typing “0169”
    Did I get that part right?
    (I clicked on several fields of the spreadsheet to no avail.)
    Mims
  • Theo Van laar
    August 15, 2011 at 7:27 pm
    It does work, but only when you use the numeric numbers on the right side.
    If you use the numbers on top, you will ger the spreadsheet you mentioned.
    Theo
  • Mike Hinkel
    August 15, 2011 at 8:10 pm
    Thanks for pointing that out, Theo. I never gave that a thought as I always use the numbers keypad for the shortcuts.
    I hope this helped, William
  • William Mims
    August 15, 2011 at 9:01 pm
    Thanks to you both, that worked perfectly using the number pad.
    You guys are awesome!
    Mims
  • Mike Kujbida
    August 15, 2011 at 9:41 pm
    William, just as an FYI, you can use any text symbols you want in Vegas.
    The easiest way is to go (on an XP machine) Start – Programs – Accessories – System Tools – Character Map.
    Choose the font you want, click on the symbol and it will give you the correct keystrokes to use.
    This lets you use symbols such as ©, ®, ±, ¢, etc. etc.
