Activity › Forums › Adobe After Effects › Text getting cut off when rotating X and Y
Posted by Leonardo Faltoni on April 19, 2015 at 9:29 pmI’m trying to make this text (3d object) rotate on the X axis but pieces of it are getting cut off.
Any idea what might cause it?
John Cuevas replied 11 years, 5 months ago 3 Members · 3 Replies -
Joseph W. bourke
April 19, 2015 at 10:15 pmTry moving it forward on the Z axis. It’s getting cut off because you have it intersecting with the layer beneath it.
Joe Bourke
Owner/Creative Director
Bourke Media
http://www.bourkemedia.com -
Leonardo Faltoni
April 19, 2015 at 10:27 pmNot sure what you mean, but I’ve tried copying the layers onto a new composition and it doesn’t seem to be conflicting with anything as of now.
John Cuevas
April 20, 2015 at 1:00 pmWhen they were in the original composition, your background layer(solid with a ramp) was in the same 3D space as your letters. Joseph was suggesting moving the background farther back along the Z axis so the it wouldn’t cut off the letters. Use the custom view settings(under the comp window) and you will get a better idea of what is happening.
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb.
