Text generated media, Sony vegas pls help
Posted by Josh Ford on September 17, 2008 at 11:18 pmHello,
I have been looking for at least an hour how to fix this problem of mine. I can’t edit my generated media in sony vegas. I tried to reset it to factory defaults and it still does not work at all. I click the green button and nothing happens at all. When I drag n drop generated media into my timeline it just pops up on default settings no matter what. My toolbar is also not locked so I know thats not it. I can’t figure out what in the world is going on its frustrating the living day out of me.
Brandon S. payne replied 16 years, 1 month ago 6 Members · 10 Replies -
Edward Troxel
September 18, 2008 at 12:42 pm -
Josh Ford
September 24, 2008 at 9:40 pmThanks for the reply and that was the problem, I fixed it awhile ago. However, I didn’t think my post went through so I didn’t come back to clarify that. Man it was bugging the living hell out of me. I tried to reset all things to default and change my resolution, but none of that worked so I had to move my start bar to the side. I would like to know what caused it though because I never directly moved the box from were it pops up on default. It goes perfectly with how I set up all my boxes.
Gill Vane
December 1, 2009 at 11:32 pmThis saved my life. Thank you. I was editing a short film, and was on the very last credit and lost my generated media edit window.
I didn’t know what I was going to do, because there was no way to finish the credits, and a new install would mean a total re edit and countless hours of work down the drain.
Thanks.
Jonathan Bommerez
July 21, 2010 at 2:27 amPlease please please explain in more detail! This is becoming a huge problem for me. What “start bar” are you talking about? The taskbar? My taskbar is locked, if that helps at all. How do I minimize the start bar? Where is that option? Please respond, I have to meet a deadline
Libby Hughes
August 3, 2010 at 8:41 amUm…hi?
I know the original post is like…2 years old, but I’m having the same problem with my own Sony Vegas.
It’s going to sound totally noob, but how do you minimize the start bar?
And if Vegas closed before I could do anything to try and fix the problem, will the generated media box still be hidden under the start bar?
Sorry for the annoying questions ._.
Edward Troxel
August 3, 2010 at 6:47 pm -
Brandon S. payne
August 8, 2010 at 8:57 pmI’m having a problem with my generated media… the rest of the video scales the screen correctly, but for some reason, my noise texture REFUSES to scale left and right beyond a certain point. It’s frusrating me, ’cause I’ve tried the Aspect ratio unlock, I’ve tried the event pan/crop tab… I have no idea what to do. It’s the only thing left in my video to fix. :/ Help?
Edward Troxel
August 9, 2010 at 12:49 pm -
Brandon S. payne
August 10, 2010 at 11:26 pmHi, this actually didn’t work. For future reference, I found that adjusting the box under the Track Motion section allowed me to increase the size of the generated media so it fit on the screen.
