Activity Forums Adobe After Effects Text fuzzes out when pre-composed
  • Text fuzzes out when pre-composed
    Posted by Antony Buonomo on August 5, 2005 at 6:32 pm
    I have some background layers with text moved away in the ‘z’ direction. There is a light shining on these layers so the text casts a shadow. Fine. Call this comp LAYERS.
    I drag LAYERS into my MAIN comp and set up a camera. However, while the text looked great in LAYERS, it looks crap and soft in MAIN. If I click the ‘collapse transformations’ the text looks ok, but I lose the lighting effect from LAYERS; ie. no shadows.
    Everything is set to best and ‘continuous rasterization’ is on for all vector lyers.
    What’s going on?
    A
    Serge Hamad replied 21 years, 1 month ago 2 Members · 1 Reply
  • Serge Hamad
    August 6, 2005 at 4:54 am
    You could create a new light layer in the main comp. As long as the ‘collapse transformations sitch is on for your layers comp you should get your shadows back.
    Salut.
    Serge
