Activity › Forums › Apple Final Cut Pro Legacy › Text fussy Blury
  • Text fussy Blury
    Posted by Tim Glidewell on August 30, 2010 at 5:20 am
    I’m reordering some pages of text off the internet with the app iShowU HD,
    trying to do an on screen tutorial to output to DVD. I’m also mixing it with HDV footage from my canon XH-A1. All the stuff I recorded with iShowU is set up to capture the same size as my sequence setting in FC 1440x1080i60. When I run a small test, 20sec sequence or so from FCP, send that to Compressor, use the DVD: best quality 90 minutes setting in Compressor. Then do my thing in DVDSP well you can’t even read the text anymore. I’m going from HD to SD in compressor on purpose. I need the text in this project to crisp, as it should be. Thanks in advance.
    Tim
    Tim Glidewell replied 16 years, 1 month ago 1 Member · 1 Reply
  • Tim Glidewell
    August 30, 2010 at 6:24 pm
    Thanks for the response. Do you mean just click and drag the web page up or down, how do I know how far to move it?
