Activity Forums Adobe After Effects Text function promblem…I think…
  • Text function promblem…I think…
    Posted by Josh Braun on February 20, 2008 at 7:36 pm
    Well, I’m new to AE and I was watching the “Digits Man” tutorial and when it said to fill the composition with numbers with copy and paste about half-way or a little more than half-way down the composition all the numbers just disappear…
    I don’t know if its a setting that I need to change or something else. Anybody know???
    Terry Coolidge replied 18 years, 3 months ago 4 Members · 3 Replies
  • James Chambers
    February 23, 2008 at 5:40 am
    I’m having the same problem..
  • Yaron Keinan
    February 24, 2008 at 12:40 am
    I encountered the same problem. Took advantage of my Hebrew skills and wrote to Eran Stern’s site. Will keep you updated. However you can download the project file from Eran’s site, and use the “numbers” comp (only that because otherwise its just copying..). By the way I warmly recomend Eran’s tutorial DVD.
  • Terry Coolidge
    May 8, 2008 at 8:57 pm
    Anyone ever find out what the deal was here? I’ve just run into the same trouble. Pasting numbers trying to fill the composition, and at some point (when there are too many characters, maybe?) the numbers just disappear. For me it happens before I’m even half-way down the comp.
    I’m using a brand-new, 3.06GHz Intel Core 2 Duo iMac. Could this possibly be a processor issue? Graphics card issue? What else could it be? Hard to believe AE gets maxed out so quickly.
