Activity › Forums › Adobe Premiere Pro › Text from title turns bold/fuzzy in preview and export
  • Text from title turns bold/fuzzy in preview and export
    Posted by Joost Lettink on September 26, 2016 at 2:27 pm
    Hi guys,
    I’ve been having a strange problem.
    A customer asked me to place translated text in an existing video.
    The text is the same as the original in the title viewer, but whenever I go to my preview screen or export, it suddenly becomes blurry/bold.
    I’ve had issues with premiere titles making text fuzzy before so I normally create the text in Illustrator and then import it in Premiere.
    I would love it if someone knew how to solve this.
    As you can see in the image, the text is clearly different although they are the same title.
    sizes are also exactly the same
    Sequence settings:
    Progressive
    res: 590×294 (I think this might be the cause, but the customer wants to keep it like this and it shouldn’t matter…)
    Framerate: 25fps
    preview quality: full
    If you need any more questions, please let me know and I will answer them.
    Adrian Spano replied 9 years, 5 months ago 4 Members · 4 Replies
  • David Roth weiss
    September 26, 2016 at 3:58 pm
    You haven’t given us the most important information from your sequence settings, i.e. the preview files codec.
    David Roth Weiss
    Director/Editor/Colorist & Workflow Consultant
    David Weiss Productions
    Los Angeles
    David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
  • Pablo Escalera
    February 23, 2017 at 2:13 am
    Im having the exact same issue.
    My preview files codec are in I-Frame MPEG which seems impossible to change..
    In my sequence settings im using the DSLR preset (1920×1080, 23.976)
    I tried creating titles with different workflows but the problem remains.. any suggestion?
  • David Roth weiss
    February 23, 2017 at 3:15 am
    Change both sequence settings and preview files to ProRes 422… your funky text files will be a thing of the past.
    David Roth Weiss
    Los Angeles
  • Adrian Spano
    April 10, 2017 at 9:33 pm
    Hi David,
    Any other suggestions? I’m having the same issue and I’ve tried doing what you suggested to no avail.
    Adrian
