Activity Forums Adobe After Effects Text from a single line
  • Text from a single line
    Posted by Greg Hughs on February 28, 2006 at 3:14 am
    I’m curious if anyone knows of a plugin that creates character outlines from a single line. In other words, I want to have a single line animate across the screen as if drawn, then have text morph out of the line to create a word outlined by the line that continues off screen on either side of the word.
    Spritemaster replied 20 years, 6 months ago 2 Members · 1 Reply
  • Spritemaster
    February 28, 2006 at 9:06 am
    If I understand you correctly (which is doubtful), you’re looking to animate a stroke across a “skyline” path similar to this one:
    https://www.ducey.com/Graphics/FrzLogo.gif
    only with letters instead of buildings.
    What I would do is create the text in a single color, say white; add a white rectangle that slightly overlaps the lower portion of the letters; auto-trace the result using Layer->Autotrace, and finally trim any unncessary portions of the resulting mask. You’ll need to decide what to do with disconnected components of the text, for instance a “T” will give you a single path but an “M” may give you two or three.
    Once you have the appropraite mask, it should be a simple matter to stroke it, add glow, animate the stroke location, etc. You can use either the Stroke effect, or Vegas, or even Trapcode’s 3D stroke for some more control.
    AA
