Activity Forums Adobe After Effects Text following a subject – is there a plug in
  • Text following a subject – is there a plug in
    Posted by Eve Myhill on May 2, 2012 at 6:25 pm
    I’ve seen this on a few adds and wondering if there is a plug in or ‘cheat’ to anchoring text to a moving subject or even keeping it fixed to a subject as the camera moves around.
    I want to keep the perspective without the complications of rotoscoping.
    Is there a plug in for this, or do I have to keyframe?
    Walter Soyka replied 14 years, 4 months ago 4 Members · 3 Replies
  • John Cuevas
    May 2, 2012 at 6:48 pm
    This is generally done by motion tracking a subject then using the motion tracking data to attach the text to the subject. Here’s a simple tutorial(part 1 of 2) illustrating how it can be done:
    https://www.youtube.com/watch?v=8pjXZkmpIzU
    For more complicated setups you could use cameratracker(or other plugins that solve cameras), but generally that’s not necessary. Usually you can use AE’s tracker or Mocha(3rd party software that ships with AE)
    There are 100’s of tutorials for learning to use both trackers. AdobeTV has quite a few that are pretty good.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Benjamin Ausmith
    May 2, 2012 at 7:40 pm
    Seems like this is really easy to do in CS6 using the built in camera tracker! Haven’t had the chance to get my hands on a copy yet, though.
  • Walter Soyka
    May 2, 2012 at 9:35 pm
    As Benjamin said, this is quite easy with CS6’s new 3D tracker, and as John said, if you need to do it today, CAMERATRACKER from The Foundry is a great choice.
    One thing to add, though — camera tracking doesn’t necessarily obviate the need for rotoscoping [link]. If you want the 3D text to obscured by other objects in your footage, you may need to do some roto to generate a matte.
    Walter Soyka
