Activity › Forums › Adobe Illustrator › Text following a path adjustments
  • Text following a path adjustments
    Posted by Charles Green on August 16, 2011 at 12:03 pm
    Hi all.
    I made some text folowing a path and noticed it always follows the path based on how it’s drawn (in point to outpoint). Is there a way to change the in and out point of a path or the alignment of the text to the path? I added a image to explain what I mean. Both paths was drawn from point A to point B and in both cases I would like the text to appear on top of the line.
    Thank you in advance,
    Charles
    Tylor Larson replied 15 years, 1 month ago 2 Members · 3 Replies
  • Tylor Larson
    August 17, 2011 at 9:37 pm
    use the Hollow arrow AKA “White Arrow” and click and drag the T. Look at the attached image.
    2817_trash.png.zip
    this allows you to change which side of the path the type will appear on… this also work for the end of the type as well.
  • Charles Green
    August 18, 2011 at 8:16 am
    perfect! 🙂
    Thanks alot Tylor.
    Charles
  • Tylor Larson
    August 18, 2011 at 2:07 pm
    not a problem… type on any path can be a pain if don’t understand how the controller works.
    Ty
