Activity › Forums › Apple Motion › Text facing Camera?
  • Text facing Camera?
    Posted by Thomas Frank on December 5, 2013 at 10:09 am
    is there a way to have the Text face the camera at all times in a 3D scene?
    The camera is rotating around a map and I like to have the city names facing the camera.
    Thank you
    Thomas Frank replied 12 years, 9 months ago 3 Members · 14 Replies
  • 14 Replies
  • Simon Ubsdell
    December 5, 2013 at 12:23 pm
    Easiest way is to make the text layers 2D rather than 3D. Would that work for your project?
    Simon Ubsdell
    http://www.tokyo-uk.com
  • Thomas Frank
    December 5, 2013 at 1:24 pm
    Well the text are on top of a location (City) and should stay at that position just facing the camera. Like something from Google Earth
  • Simon Ubsdell
    December 5, 2013 at 1:34 pm
    Try linking the XYZ rotation of the Text layer (or text group) to the rotation of the camera. That should do it.
    Simon Ubsdell
  • Mark Spencer
    December 5, 2013 at 1:44 pm
    You can use the Point At behavior to have the text always face the camera. Set the transition to zero.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Thomas Frank
    December 5, 2013 at 1:59 pm
    Nope it didn’t work. 🙁
  • Mark Spencer
    December 5, 2013 at 2:00 pm
    It certainly works for me. Did you add the camera to the source well? Change the transition time?
    Mark Spencer
  • Simon Ubsdell
    December 5, 2013 at 2:04 pm
    I thought that Point At only gave you the option of one axis? I guess you’d need to have three instances if you wanted it completed locked.
    Link rotation is marginally easier in this case possibly?
    Simon Ubsdell
  • Mark Spencer
    December 5, 2013 at 2:19 pm
    Yes you need to choose an axis but if you choose the default, z, and set the Transition value to 0, the text will always point at the camera – it’s z-axis will point at the camera.
    Mark Spencer
  • Thomas Frank
    December 5, 2013 at 2:20 pm
    I add the camera to the well but the text spun in another direction and its not moving with the camera
  • Mark Spencer
    December 5, 2013 at 2:21 pm
    I can’t tell what’s wrong without seeing your project but if you set the Transition value to 0 and the Source to the Camera with the Z-axis selected, the text will face the camera. Is the text in a 3D group? Tough to trouble shoot but absolutely should work.
    Mark Spencer
