Activity Forums Adobe After Effects Expressions Text expression to go quicker over time
  • Text expression to go quicker over time
    Posted by Caleb Sandoval on July 9, 2013 at 11:12 pm
    I am trying to change the speed from one point in time to another for the quiver text expression. I clicked the stopwatch but it brings up a yellow box. i tried changing the axis and the wiggles/second from the two places in time I wanted it to occur but it is not changing over time. It simply stays the same and changes when it arrives to the second yellow box.
    Todd Kopriva replied 13 years, 1 month ago 3 Members · 4 Replies
  • Todd Kopriva
    July 10, 2013 at 5:56 am
    The “yellow boxes” that you’re referring to are keyframes.
    I strongly recommend that you start here to learn After Effects: https://adobe.ly/bjBT3P
    After Effects team blog
  • Mitch Mann
    July 10, 2013 at 2:50 pm
    Not sure I understand exactly what you’re saying, but if you do the animation in a preComp, then you could simply use time remap to increase the speed over time in the main comp.
  • Caleb Sandoval
    July 10, 2013 at 4:53 pm
    right i understood that, but usually my keyframes are usually diamonds. I thought that there was a reason why it was a box instead of a diamond this time. maybe the reason I couldn’t get it to do what i needed it to
  • Todd Kopriva
    July 10, 2013 at 5:03 pm
    See this page for the various keyframe types, including Hold keyframes.
