Activity Forums Adobe After Effects Text effect in AE 5
  • Text effect in AE 5
    Posted by Mike Cornett on March 14, 2007 at 2:20 pm
    I’m designing a countdown for my programs. I’m using the Text effect in AE 5.
    The numbers are not accurate to the timeline. “10” is up for only 15 frames, and then I believe each number is on for a second.
    How can I make this accurate without having to physically make and position each number??
    Thanks.
    Kevin Camp replied 19 years, 6 months ago 3 Members · 2 Replies
  • Jim Kanter
    March 15, 2007 at 3:31 pm
    Have you checked the frame rate for the composition?
    Jim Kanter,
    Digital Film Institute
    http://www.dfilminst.com
  • Kevin Camp
    March 15, 2007 at 3:40 pm
    i assume you used the numbers effect, and set keyframes for you count down, starting at 10 on frame 0 and ending on 0 at the 10 second mark.
    try setting the value of 10 to 10.49. i think what is happening is that 10 is counting down is decimals and getting rounded to the nearest number so half way between 10 and 9 it hits 9.49 and rounds down.
    you could also try an expression that would only generate whole numbers. or, add 1 second to your comp, start at 11 and back time your countdown layer 15 frames. or, you could use hold keys frames at each second and enter a value.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
