Activity › Forums › Apple Final Cut Pro › Text Effect Advice – FCPX
  • Mark Suszko
    July 21, 2015 at 4:26 pm
    Change your blending mode, it is next to the opacity level control.
  • Harriet Allen
    July 21, 2015 at 4:28 pm
    I can’t seem to see it?
  • Bret Williams
    July 21, 2015 at 4:55 pm
    Actually looks like the background is inside the text, but offset vertically (or perhaps in time if the camera is moving around). The video within the text is brighter somewhat.
    Duplicate the background and nest it in a compound clip with the text. Inside the compound, make sure the text is above the background and for the text’s blending mode in the inspector choose stencil alpha. That puts the background inside the text. Choose the background video layer and change it’s brightness and position. Go back to the main comp and check out the result and adjust to taste.
  • Harriet Allen
    July 22, 2015 at 8:13 am
    Thank You, I’ll try that.
