Activity Forums Adobe After Effects Text edges look jittery after enabling 3D layer
  • John Cuevas
    February 11, 2013 at 7:46 pm
    That picture is pretty small, but it looks like you are using Ray-traced 3D with a low Ray-tracing Quality setting. If you don’t need ray-tracing I would suggest you press “Cntl+K” and use the advance tab and change the render engine to “Classic 3D”.
    If you do need Ray-tracing to get better quality you need to access the options(it’s the pulldown with a lighting bolt in the comp window)and go to Renderer options and increase the Rays. This will cause a hit to render each frame though. I generally work in draft and if I need to check the work,will increase the Ray tracing, and then go back to draft quality and continue working.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Benjamin Finkel
    February 11, 2013 at 7:51 pm
    You, Sir, are awesome!
    Thank you.
