Activity Forums Adobe Photoshop text disappears when saving PDF
  • text disappears when saving PDF
    Posted by David Griffin on October 21, 2008 at 3:32 pm
    Hi there, a little help would go a long way…
    I’ve just upgraded to PSHOP CS3 and am trying to lay off a flat PDF from a layered PSD to email for client approval.
    I’m SAVING AS COPY i.e. no layers. When I open the PDF all the text is missing from the image. I guess it’s something to do with vectors but I can’t seem to get the right settings simply to flatten everything down to a raster image.
    Any thoughts out there?
    David
    William Sticht replied 17 years, 11 months ago 2 Members · 1 Reply
  • William Sticht
    October 21, 2008 at 5:20 pm
    Save the file under a different name (so you dont ruin your original). then flatten you image before creating the pdf. I cant explain what is causing your text to disappear, but this should get your pdf image to your client.
    Good luck,
    Fritz Sticht
