Activity › Forums › Apple Motion › Text disappears when adding behaviors
  • Text disappears when adding behaviors
    Posted by Jessica Roberts on February 23, 2011 at 10:08 pm
    Hi, I’m using Motion 3 to make a kinetic typography for class, and I’m having issues with behaviors.
    I have each word in a different text layer and I would like most of them to have a behavior. Originally I tried adding a simple fade to one of the words, and when that happened the word completely disappeared. I can still see the box on the screen to move around, but the text does not show up no matter if I scrub down the timeline or play it at different render qualities.
    Even changing the opacity manually makes the same problem happen. Anything under 100% opacity makes the text completely go away no matter how many settings I change.
    Please let me know if you can help!
    Thanks.
    David Eaks replied 15 years, 7 months ago 2 Members · 1 Reply
  • David Eaks
    February 24, 2011 at 2:46 am
    Sounds like disappearing word it is behind another layer, open the “layers” tab and try moving the missing text to the top.
