Activity › Forums › Adobe After Effects › Text depth
Text depth
Posted by Rcmsantos on August 19, 2005 at 1:33 pmHi,
How can I give some volumetry to a text layer?
Thanks on advance
RCMS
Steven Bump replied 21 years, 1 month ago 4 Members · 4 Replies -
Steve Roberts
August 19, 2005 at 1:43 pma) buy zaxwerks invigorator
b) Apply AE’s effect>simulation>shatter. If you use shatter to give the text depth, and remove everything around the text by shattering, it can work. Search the COW tutorials for more on that one.Invigorator is probably better for you, though.
Steve
Bobby Walker ii
August 19, 2005 at 3:21 pmCreate your text layer.
Turn on the 3D Switch for the layer.
Duplicate the layer 5 or 6 times.
Offset the z-position of each layer by 2 or 3 from each othe (example: text layer one z-position=0, text layer two z-position=2, text layer three z-position=4, etc.)
Parent the duplicate layers to the original text layer or pre-comp.
Instant 3-D text from just about every camera angle as long as you don’t zoom in too tight!!
hth
bobby walker ii
broadcast video COWG5 2.5GHZ DP,2.5 RAM, AJA IO LA, Medea G-Raid,FCP HD
Steven Bump
August 19, 2005 at 5:39 pmDigital Anarchy has a plug in called 3D layer that’ll do this…
https://www.digitalanarchy.com/3Dlayer/3Dlayer_main.html
