Activity Forums VEGAS Pro Text cutted. Is line too small for this?
  • Text cutted. Is line too small for this?
    Posted by Miguel Lopez on May 7, 2019 at 8:21 pm
    Hello everyone!
    Maybe you can help me with an issue. There’s a certain font I’m having problems with. I tried to look for an option to make the text line a little bigger, but I haven’t found any.
    Result:
    As you can see in the images, seems like the font is too big to fit in the line. Is there a way to deal with this?
    Thanks in advance.
    Miguel Lopez replied 7 years, 4 months ago 2 Members · 4 Replies
  • Francois Pénzes
    May 8, 2019 at 12:25 am
    Hi Miguel
    Your links are not working. Can you post them again ?
    Cheers !
    PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
    Cameras: Canon XF305 + Canon XH-A1
    Blackmagic HyperDeck Studio Mini
    Vegas Pro 16, User since Vegas 3.0
    \’\’When the cutting stops, the editing begins…\’\’
  • Miguel Lopez
    May 8, 2019 at 2:05 pm
    Hello, Francois.
    Sure I can. They were images. Here is the first one:
    And the next:
    Thanks inadvance
  • Francois Pénzes
    May 14, 2019 at 9:52 pm
    Hi Miguel
    Sorry about the delay in my reply. I tried a lot of different ways and I could only get what you got the cut) using your font (Allison Script) in Legacy Text.
    However, when using Titles & Text, I got a perfect result with no cuts.
    if you really need to use the Legacy Text option, then I recommend you use Allison Tessa. It looks like the other one.
    Here are the results:
    Legacy text with Allison Script
    Title & Text With Allison Script
    Legacy Text with Allison Tessa (maximum size 44 before starting to cut. Use Track Motion Box to re-size if needed. It may get a little blurry)
    Hope it helps.
    Cheers !
  • Miguel Lopez
    May 15, 2019 at 2:47 pm
    Thanks so much Francois.
    This helped A LOT. I think I can say “Problem solved” – You are so kind,.
    Best regards
    Miguel
