Activity Forums Apple Final Cut Pro Legacy Text crawl speed control
  • Text crawl speed control
    Posted by Ben Neufeld on February 13, 2012 at 5:39 pm
    I’m editing a documentary in FCP 7 that incorporates a large amount of text that I plan on crawling across the bottom of the screen at various points throughout the movie. I’m experimenting with the Boris text crawl effect which seems like a better one than the FCP crawl, but I’m wondering if there is any way to control for crawl speed and make clip duration variable? I understand the normal way to set the speed is to make the text clip longer or shorter, but for my purposes I would like to have a constant speed for all of my text crawls with the clip duration variable. Does anyone know of a way to do this?
    Ben
    Alexis Revitsky replied 14 years, 7 months ago 2 Members · 5 Replies
  • Alexis Revitsky
    February 14, 2012 at 12:05 pm
    When you have the text box selected there should be a window tab ‘control’ in order to do this. I recently did a video with text blocks that faded in over video. I actually went to Motion and “animated” the text to my liking with a transparent background. I found that to be the best way to control the text’s speed and have consistent control.
  • Ben Neufeld
    February 14, 2012 at 4:09 pm
    Hey Alexis,
    I am trying to work with a large amount of text that would be too cumbersome to animate with motion, I am working with the text crawl function which moves text ticker style across the screen. My text is in discrete sections though and I am looking for a precise control to standardize the crawl speed of the different sections of text, as it seems the speed is determined as a default by the clip length and amount of text. I want to make clip length variable and control for speed, I don’t believe that motion can do this.
    Ben
  • Ben Neufeld
    February 14, 2012 at 4:44 pm
    In addition, I just actually came across another problem–I don’t know if anyone has input on this–I was able to change the speed of a text clip made with the Boris Title Crawl generator using the basic FCP speed control (after I reached the clip limit, which seems to be 2:00;04). I then tried doing the same thing on a second text clip, and when I applied the speed change the text just seems to disappear. Anyone have experience with this?
    Ben
  • Ben Neufeld
    February 14, 2012 at 5:36 pm
    Just found a solution. Plug in found here: https://alex4d.wordpress.com/2009/08/17/fcp-plugin-text-crawl/ has a speed control along with a variety of other options.
    Ben
  • Alexis Revitsky
    February 15, 2012 at 5:46 am
    Hi Ben
    Motion can control the speed. It’s in the settings function on the animation you create. I have changed the text animation speed in motion on a recent project. I’d like to help you more; unfortunately, I’m out of state and won’t be in close proximity until Thursday. Email me if you’d like help.
