Activity › Forums › Apple Final Cut Pro Legacy › text crawl problem
text crawl problem
Posted by Roberto Yambo on March 5, 2010 at 4:03 pmI have a project that has a crawl at the bottom of it. In FCP it looks great but when I export using Apple Pro Res 422 HQ or H.264 the crawl doesnt look clean everything else looks great though. What type of compression should I being using?
Thank u
Roberto Yambo replied 16 years, 5 months ago 3 Members · 11 Replies -
Roberto Yambo
March 5, 2010 at 5:19 pmI have changed the field dominance of my sequence settings as well. I also tried doing the crawl in Photoshop to still the same problem.
Alan Smith
March 5, 2010 at 6:24 pmSo you have HD footage with a scrolling text that you are outputting to SD?
If so, you will need to view it on a SD monitor to know if it is correct of not. The SD is going to be a lower res video, interlaced and you are watching it on a high res progressive display. You will see artifacts that should not show up on a SD monitor. The only way to know for sure is to view the finished piece on an SD production monitor.
Alan Smith
Media317Check out my blog – https://media317.com
Mark Petereit
March 5, 2010 at 6:25 pmFirst rule of production for SD broadcast: you need to view your output from a SD broadcast card on a SD broadcast monitor.
Roberto Yambo
March 5, 2010 at 6:32 pmmy footage is SD, I have a Small plasma I wanted to hook up as a monitor but I dont know how, I am pretty new to the editing game.
Roberto Yambo
March 5, 2010 at 6:34 pmThanks by SD card do you mean like an AJA Box? I am new to the game and I am working on a small budget. I use a macbook pro 17′ and I have no output monitor at the moment.
Mark Petereit
March 5, 2010 at 8:34 pmDave’s right (as usual.) Just because you can edit on a laptop doesn’t mean you should. And really, there’s nothing inherently wrong with editing on a laptop — just realize that if you’re producing a piece for broadcast, you’re never going to know how it really looks until you move it to a desktop system equipped with a broadcast video card and broadcast monitor.
Another thing you’ll probably need to be aware of is making sure your piece is broadcast-safe. There’s a very real possibility that you could deliver your final product to the broadcaster and have them simply reject it because it’s beyond broadcast legal limits.
Ask your broadcaster for their technical submission guidelines (they’re different for every broadcaster) and follow them to the letter. If you don’t understand something in their specs, ask here.
