Activity Forums Adobe After Effects Text clipped on dynamically linked text to Premiere :-(
  • Text clipped on dynamically linked text to Premiere :-(
    Posted by David Honan on August 6, 2015 at 1:54 pm
    Hi from always cloudy about to rain York Uk 🙂
    Working in both premiere and After effects Ive hit a problem with dynamically linking below illustrates my problem:
    9117_clippedtext.jpg.zip
    Basically as the above link “Should” illustrate I cant get my works space to match the same dimensions as abode premier. Bloody nightmare! Gone into settings just cant work this one out. As stands I have a tiny workspace area in After Effects, but I need it to match premieres work space area if this makes sense.
    Any advice welcome 🙂
    David Honan replied 11 years, 1 month ago 2 Members · 2 Replies
  • Walter Soyka
    August 6, 2015 at 2:57 pm
    Change the size of the comp in Ae in its composition settings (Cmd+K Mac, Ctrl+K PC).
    It looks like perhaps your Ae comp is 1280×720 but your Pr sequence is 1920×1080.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • David Honan
    August 6, 2015 at 4:27 pm
    Brill thank you your suggestion worked 🙂
