Activity Forums Adobe After Effects Text Chatter
  • Text Chatter
    Posted by Richard Kratt on December 20, 2013 at 6:17 pm
    I am doing a small scale up of black text files I received in Illustrator. They are in a precomp and scaled up to 418% and I have “collapsed transformations.” In the main comp I’m scaling the text from 100 to 110% and there is a chatter. How do I get rid of the chatter? I’m at a loss.
    Thank you so much in advance.
    Rich
    Roland R. kahlenberg replied 12 years, 8 months ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    December 20, 2013 at 7:59 pm
    When ever possible, do all your scaling in a single comp. In your case, do it in the precomp.
    I can’t visualize “chattering” on text as such a description is not usually ascribed to text. But try the procedure above and see if it solves your issue. Otherwise, provide a sample movie and include details of all the properties that you have changed/keyframed.
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
